Easy Outside USB jacks...
Rbertalotto
I wanted to be able to charge my devices while I'm sitting outside under the awning. The easiest method was with this device.
TOPGREENER TU21548A 4.8A Duplex USB Charger Outlet
Simply replaced my duplex with this device...Done!
Upgraded High Speed Charging Tech: World's First Smart Ultra-High Speed Dual USB Charging In Wall at 4.8 Amp, 24W, 5VDC
Charging-Smart Technology: Dual "Smart" USB Ports Precisely "Read" the Power Need then Maximize Charging Efficiency
Design Innovation: Interchangeable Face Cover. 3 Color Face Cover Included: White, Black, Light Almond
Two TR Tamper-Resistant Outlets enhance electrical safety, preventing the attempting to insert objects into the outlet; Meets 2011 NEC
Compatibility USB 1.1/2.0/3.0 devices, 2 USB ports total 4.8 Amp, 5VDC; Two TR Receptacles 15 Amp/125VAC; UL lsted; 2 years warranty; Back & side wiring easy installation. Wall plate not included
About $20 on amazon
http://www.amazon.com/TOPGREENER-TU21548A-Resistant-Receptacle-Interchangeable/dp/B01BTC5I5O?ie=UTF8...
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
6 REPLIES 6
pconroy328
I had a TopGreener in the house that, after about 3 months, the USB ports just stopped working. IIRC others had that issue too. I just swapped it out, today, for another brand that I found at Home Depot. I'm hoping the other brand lasts longer.
Be gentle with it and maybe it'll last longer than mine did.
GordonThree
RoyB:
Electrical insulation. All my RV outlets, including the outdoor on clamp onto the wires in a parallel arrangement. There are no bare wires or exposed terminals.
Only an extra outlet and wiring I added have bare wires wrapped around exposed terminals. This outlet I put in a surface mount wall box.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
Rbertalotto
Very nice but here is one that will work on 12 volt power. 12 volt
That is a nice, clean , way to mount 12V receptacles. Thanks for the lead!
I used a bunch of these throughout the camper.
But the one you posted would fit nicely in an outside weather box.
RoyB
Dartmouth, MA
Rbertalotto
Is it insulation displacing like typical RV receptacles?
If you mean wall insulation.....This is a typical , poorly built, RV...There was zero insulation in this wall cavity. I used an inspection mirror to see if there was any up or down...Nope!
This was a wall cavity where lots of wires were run and I guess they just thought it wan't needed.
And you should have seen how the hole was cut in the side of the trailer for the receptacle. Only one screw out of four hit anything. It was basically held on with the Dicor sealant!
RoyB
Dartmouth, MA
corvettekent
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
GordonThree
