I just love it when your phone or computer decides to do something you don't want.I always liked that with Firefox,when you typed something in the search box,it didn't suggest a whole bunch of******you didn't want.The only thing you would see would be places you previously searched which was nice if you went back to the same site alot. Now out of the blue,it started showing all these suggestions as soon as I type the first letter.And it doesn't show the things I went to before. If I wanted an Internet Explorer type browser I would have downloaded that.Can I change it back to the way it was?
If that didn't work, then you either have a corrupt profile. Or picked up some kind of browser hijack such as a PUP.
Try downloading AwCleaner to your desktop, and run a scan. It's portable, and doesn't need to be installed. Do a Scan first, and review what it found in each tab? Then click on Clean. Once it's finished, it will require a re-boot for anything it detected in your registry.
Export your bookmarks Uninstall Firefox Download fire Fox manually Choose the last version Not the newest one from the top of list Install Import bookmarks
I can explain it to you. But I Can Not understand it for you ! ....
Connected using T-Mobile Home internet and Visible Phone service 1997 F53 Bounder 36s
RGar974417 wrote: Thanks> I tried it but it didn't work.
Play around with items checked a shown..It should work fine...
Gary And Cathy '05 Dolphin 5342 Honda Element following us :W Pacnats GS, FMCA :C Rallys attended FMCA Albany, Or.'06 FMCA Redmond, Or.'07 FMCA Quartzite, Az. '10...but not again:R Good Sams "The Rally" Redmond Or. '11 FMCA Redmond August 2014 FMCA Indio, Ca 2013
If you go into Firefox Tools>Options>Privacy Tab, you can select from the Location Bar's drop-down options what suggestions to display when you type a URL or a search in the address bar. For instance, you can limit it to bookmarks only, or nothing at all if you want. Make sure to click OK when finished.
