Hey all! (Please move if in the wrong area) I am getting back into RV'ing after a short hiatus. I am re-entering having purchased a 2006 Four Winds Hurricane 34N.
Good rig, and the 2 TV's have been changed out to flat screens.
However, the owner just set them up to run off of cable only, and there is a small silver splitter that sends the feed to the back TV. On top of that the rig has an original in motion sat on the roof which doesn't work today. The original switch box is long gone as it died several years ago.
The front TV cabinet looks like a spaghetti western!!! A huge rats nest. He stated he never used the batwing antenna, and I don't even know if the antenna wire is still routed in the cabinet, but it could be among the mess.
Here is what I want to do....and would love your advice on.
1. Eventually I may get a Dish tailgater, but not now. I won't be using the rig for a while (remodel in play). Should I prepare for this now? If so, how?
2. I want to get the TV cabinet organized,
3. I need to find the antenna feed. I need to get it operational, or connected so it picks up over the air stations. Whats the best way to do so short of tugging on the cable from the roof? Is it a different color or thickness?
4. My past rigs had an antenna power switch, but there is none to be found in the cabinet. Any ideas on why that may be? Will this be an operational issue?
5. I want to install a couple DVD's in the rig. I will need a switcher of sorts I am assuming to go from antenna to cable to dvd....any ideas on what is on the market today that would work for this? Hopefully one that would accommodate the future Dish option. What is everyone using who's had to do an upgrade like this? Do I need a modern switch of sorts? One of those black boxes that will allow options in viewing? IF so, one or two?
6. Would you remove the huge in motion dish up on the roof, or let lying dogs sleep? It is not creating a leak issue at all.
The seller left a cable tester device which should come in useful once I figure out how to use it lol.
Thanks for reading this long post, and I appreciate all input!
2014 Jeep Cherokee 4X4 Toad
USAF Veteran. 75-81 SAC "Giant Talk" ATC-
Combat Crew Communications
Squealers = Steelers & Arkansas Razorbacks Fan
