How To Charge 5 Apple Products
1ed
What do people do to charge 5 apple products will in your TT?
I would like info on both when working off battery power and when I am hooked up to shore power. Picking up new trailer next week and I believe there are 2 USB ports in the trailer.
I will have 2 Golf Cart Batteries while in the boonies.
I did Google and found some info but I value the opinions of those that have used whatever product, so I look forward to your comments. Thanks Ed
14 REPLIES 14
RickLight
I've installed these:
https://www.amazon.com/dp/B00ZOG6TBE
2.1A 5V output from each port. Mount 2 and charge 8 devices. The real load of 2.1A @5V is 11 watts which is only 1A @ 12V. Most 12V circuits are 10A or 15A, plenty of room for all your toys!
Put them where there is already unswitched 12V and check the fuse for that circuit. Mine are next to the radio and the bedroom lights. Near your control panel is a likely spot also.
On shore power just use whatever you use at home, or install things like this for your 120V receptacles.
https://www.amazon.com/dp/B013QP0OWY
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
pianotuna
Nomad II
Nomad II
Hi,
The ipads need 5.1 volts @ 2.1 amps. Make sure any adapter will handle that much current.
1ed wrote:
2 iPhone 7+ 2 iPads 1 watch.
Regards, Don
Fizz
JesLookin
I installed a couple of Blue Sea Systems 1045 usb charge ports. They get their power from 12Vdc, so they'll work whether on shore power or running off the battery.
2013 Arctic Fox 27-5L
2014 Ram 3500 6.7L CTD, Crew Cab
neschultz
1ed wrote:
Hello, Like I said I did Google it but I would appreciate a make or model that you have found that you would recommend. Thanks Ed
We have several of these and they work well.
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
Tiger4x4RV
As said before, it depends upon what Apple devices. 2.1? 2.4? USB-C, whatever that is.
My Apple stuff: a very old iPod Touch, a new iPod Touch, a very old iPad, a new iPad, an iPhone SE. All are actively used when I travel. Each has its own charging requirements.
On battery power: 3 cigarette-lighter style 12V outlets in coach and in a pinch the 12V in the dash (always live, but it works off the truck battery, so best not to use it unless the engine is running). I have been using Belkin adapters (car chargers) for years. Not finding exact same thing on Amazon today. Other vendors may have them.
On shore power: 2 110V outlets in coach. Plug strip. Or keep on using those 12V outlets as above.
Watch out for "car charger" type adapters which label their USB ports as "Apple" and "Android." Huh? I want to know - 1.5? 2.1? 2.4?
I hope this info helps you.
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
Lwiddis
With an adequate solar system recharging all my devices is easy.
1ed
pianotuna
Nomad II
Nomad II
Hi,
It depends on what the five apple items are.
Regards, Don
valhalla360
Nomad III
Nomad III
USB outlets are commodity items.
We've got half a dozen from trade shows kicking around.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Ed_Gee
Something like one of these?
Amazon results from searching - 12V multi USB charger
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
time2roll
We get by fine with a 2 port adapter in the 12v cigar connector. Make sure it has plenty of amps available for ALL ports.
I also have a 300 watt sine wave inverter to power all the outlets for using additional chargers.
1ed
rk911
EZ. just google '5-port smart phone charger" or search Amazon for the same thing.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
