iOS 10 update, info
Fizz
I've had a few annoying glitches since the latest update.
Did a lot of searching and reading up on it.
The only useful item I found was to do the upgrade through iTunes on your PC. Do the download first then plug in and update your phone/tablet.
Don't do it OTA (wifi)
It seem the people who did it this way are not having problems, the worst being excessive battery drain.
3 REPLIES 3
wildtoad
It is a good plan to use iTunes to back up before doing any updates, and then do the download and install. It is also best to encrypt these backups so it will include passwords and other secure information. I backed up all three iOS devices ahead of time in prep for the update, but did the install over my home WiFi. No known issues. As with all updates some have issues, some not.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
Fizz
The point being...
You only have two options when updating.
If people are reporting less problems doing it one way why not do it that way.
Besides that a backup is always recommended before an upgrade and that is done with iTunes on your PC.
Toddupton
You will get the same update regardless of how you do it. When you do the update through iTunes the device still installs the update. Some of the problems were early on too many people were download the updates at the same time it the servers just could not handle it. Happens the first few days of a major update. So, short answer is that it does not matter how you do it.
