philh wrote:
It's been working fine.
It was the pole power failure that manifested itself with sudden connection failure. The odd part, when I connected to the router, the thermostat worked again.
Winegard has punted and said their equipment is working.
Everyone want a piece of the pie, but no one is willing to take their fair share of the blame when something fails :M Pretty normal.
The problem is you have so many connections from the T stat to your phone which make troubleshooting even for the most seasoned tech almost impossible. If I read this correctly your chain goes like this..
T stat to Winegard Router, router to ATT cell tower, ATT cell tower talks to ATT Internet servers, back to your phone via normal cell phone Internet connection (not connected directly connected to your router)..
Things start working again if you go..
T stat to Winegard Router, connect your phone directly to the router..
By connecting directly, you are bypassing the ATT cell towers, ATT Internet servers and connections..
Sounds to me your Winegard Router is having issues when the shore power drops.. Even though your router is using 12V it doesn't mean that it is impervious to issues when the shore power is cut.
When you have shore power the converter output should be at a min of 13.2V-14.5V. Once shore power is cut, the 12V will drop to 12.6V-12.8V for fully charged battery..
Fully discharged battery is 10.5V so there is not a lot of wiggle room for voltage drop..
Verify at the router that when shore power is off you do indeed have at least 12.6V with a meter..
Verify at your batteries you have at least 12.6V with a meter with shore power off.
Other things to consider, you might just be in a area where the ATT signal is pretty weak and the slightest change in battery voltage, ATT signal strength and RF noise around or in your RV may be enough for the router to disconnect from ATT network..
But once again, way too many variables..
