Jack TV Antenna Vs Satellite
Jerry_Roberts
for those that have used both: which is better? the jack tv antennea would be a lot easier to use compared to the satellite dish, so if it gets enough channels then i won't even bother with the dish.
2014 Open Range LT308BHS
1999 F250 Diesel
34 REPLIES 34
brirene
I've not camped anywhere where I got anything close to that number of ota channels. I've gotten maybe 10-15, but not much more than that. I'm not usually very close to large cities, so that may increase the number, but its not been my experience.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Jerry_Roberts
Thanks. However, I've used Directv in the past and currently have Dish Network as my cable provider. I should have added that, I've read that the Jack TV is a lot better than the Winegard. And some people are getting 80+ channes with the Jack antennea. I don't believe everything I read on the internet, so I was wondering if there is any truth about the Jack TV getting as many channels as satellite.
1999 F250 Diesel
donn0128
The crank up antenna on my trailer has never been raised to watch TV. We rely on DTV and am totally pleased with our setup. packages are what you want to pay for. We watch very few movies any more instead rely on the two DVR's to record what we want to watch and avoid commercials when we watch them
camperpaul
The Jack and the Winegard Sensar will pick up OTA stations located in range of your location. There is no charge for watching OTA television stations.
When using a satellite dish you can get all of the 'cable' channels you are willing to pay for.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
HappyKayakers
With any antenna, you're at the mercy of the local transmitters. You could get 1 channel or 20, depending on where you are. I've been fairly lucky with antenna usage. This is my first location where I've had to resort to watching DVDs frequently.
With satellite, all you need is a clear view of the southern sky. Available channels depend on the package you pay for.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
