Jul-06-2018 03:30 PM
Aug-13-2018 09:51 PM
Aug-13-2018 05:50 PM
Aug-13-2018 12:22 PM
MrWizard wrote:Great information, thanks.
it has a removable battery good for about 20hrs
it charges via USB,
mine came with charger and cable
it has ports for an external antenna, which i bought after a month or so of using with out
it has better reception (gets a stronger signal) than the Mobley even with out the external antenna
and in a pinch can act as a portable battery to power your cellphone
a function you can turn on from the touch screen menu
Aug-13-2018 12:06 PM
Aug-13-2018 11:10 AM
Dutch_12078 wrote:Does the Netgear Unite Explore 815S come with a charging cable and plug? Is it just a USB like an android phone?concord 05 wrote:
As I said before I am not tech savey. I have spent some time rereading the posts. I think the best solution for us is the Netgear device. Is it really as simple as moving the SIM card to the new device. If it’s anymore technical than that I’m sunk.
Yes, it's really that simple...
Aug-10-2018 04:14 PM
concord 05 wrote:
I do believe the Hulu rep said the changing ip address is the problem with the Mobley hotspot. Even though there is only 2 of us the addition of the smart tv has pushed our 5 device limit to to the max. Came across some forum last night talking about att and SIM cards in non Mobley devices. The question being debated was would att cancel your plan if you moved the SIM card.
Aug-10-2018 04:00 PM
Aug-10-2018 03:20 PM
Aug-10-2018 08:50 AM
Aug-10-2018 07:12 AM
Aug-09-2018 07:57 PM
Aug-09-2018 06:35 PM
Aug-09-2018 04:45 PM
Aug-09-2018 04:15 PM
