Worked fine last season except once I had to use the remote to turn it on, power button wouldn't do it. Now neither power button or remote will turn it on. Still displays incorrect time. Any suggestions for a fair priced replacement, preferably with a DVD output to television (unlike this one)?
2019 Wolf Pup 16 BHS Limited, axle flipped 2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
Pried the lower facia off. Better access to the pushed in and cocked over power button. Futzed around with it with a small screwdriver and needle nose pliers, hit the reset a few times with the custom reset tool (bent paperclip), & the SOB powered up! So this lazy, cheap bastage will keep it a little longer ๐
Before you spend money that you don't need to..........
Just a few days ago I thought my radio had crapped out too, until I remembered that it gets it's main power from the HOUSE batteries and will be dead if the battery disconnect switch is OFF !!!
