โMay-30-2013 06:33 AM
โJan-23-2014 06:35 AM
โJan-23-2014 01:30 AM
RV Nomads wrote:Yes. We have a KingDome twin LNB dome dish, feeding two DirecTV DVRs. Standard definition only, as the HD service is on another satellite from the SD programming.
Just Curious... Can you get a SD receiver from either Direct or DISH with a DVR? I have a KVH in motion dome and a winegard carry-out. I'm happy to watch off-air tv when available... but sometimes it isn't. I don't need HD but I would like to record shows. I'm fulltime and don't own a home. Thanks in advance for your replies.
โJan-23-2014 01:28 AM
wa8yxm wrote:Only partially true, OM. Depending on your location, you could be using the legacy Wildblue hardware (or Exede5 as it is now known) The newer Exede service (Exede12) uses a high capacity satellite and different transmit and receive equipment. Exede12 and Exede5 both use spot beams as you stated. Their parent company ViaSat does offer a mobile solution, but it is marketed to the commercial and broadcast markets, not to RV users. And as far as I know, Exede does NOT allow users to set up their own equipment as a RV owner would have to do every time they move. Stationary installs by qualified installers only.
Exceed uses the old WildBlue Hardware.. The sats are spot beamed so you need to do a lot of work to move from one part of the country to another. This makes it very impractical for RVers.
โJan-22-2014 05:45 PM
โJun-02-2013 10:45 AM
โJun-02-2013 07:09 AM
For TV, Direct seems to be the preferred service for RVers because you can get network TV anywhere without any hassle or calling to move.
โJun-01-2013 09:00 PM
โMay-31-2013 05:22 PM
โMay-31-2013 05:31 AM
โMay-30-2013 02:11 PM
โMay-30-2013 10:33 AM
โMay-30-2013 10:22 AM
Bill.Winegard wrote:Correct.CA Traveler wrote:
We use our home DTV H24 receiver which can record 2 stations. Combined with a RF Mogul dish for the RV. All HD. The Verizon Jetpack takes care of our internet needs.
You must have an HR24 as the H24 is not a DVR.
โMay-30-2013 09:38 AM
โMay-30-2013 09:33 AM
sdianel wrote:
DirecTV and Verizon Mi-Fi is what we have.
