Winegard travler mounting inst said mound dish as level as possible so heres what i made and mounted I purchased the .140 alum winegard mounting plate and made a 11" dia. alum. ring 1" sidewall thickness and leveled my Fleetwood discovery then measured the crown of my roof at 2.5 degrees i turned the ring to 2.5 degrees then bolted it to the purchased alum plate then I cut a .25 alum. plate 1/8 bigger them the base of the travler mounting base and bolted that to the 11" ring sealed all surfaces and i am within .5 degrees of level Maybe was over kill but its level !!!!!!! sorry have pics but cant post !
โ Did you see the
"Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
"Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
