I am having fits trying to figure out what is wrong with my winegard travler SK7003 system. This system is for Shaw. The control box shows that it has found the 2 satellites 111 and 107. It goes thru the peaking and identifying procedure and shows the * by the satelites. The problem is, it has actually not found them. The azimuth appears to be ok but, the elevation looks to be too low. I get no signal at the receivers. All of the coax cables are good. I have even connected directly from the lnb to the receiver to verify that there is no signal. I believe it is close because the satellite strength meter option shows occasional blips of signal but nothing steady. I am using 600 and 630 receivers that are all active on my other dish.
I am very puzzled as to what the control box is finding that it thinks are the required satellites. It has me extremely puzzled. I have recalibrated the elevation and reset the box to factory settings. I will be talking to the support at Winegard on Monday but, if anyone has any suggestions, please let me know.
Roy
2011 GMC 3500, Duramax, Allison
2008 HitchHiker LS 29.5 FKTG with most options
