โMar-12-2018 11:58 PM
โMar-15-2018 08:56 PM
โMar-15-2018 02:57 PM
โMar-15-2018 11:08 AM
โMar-15-2018 04:15 AM
โMar-14-2018 08:16 PM
โMar-14-2018 04:13 AM
Chad Heiser wrote:
The direct TV head (dish and LNB) is heavier than a Dish Network head. I am not that familiar with Shaw in Canada, but I think the head is comparable to Dish Network.
A Direct TV Travโler head can be changed out to a Dish Network head, but you canโt go the other direction. The reason for this is the weight of the head and the construction of the lifting mechanisms (motors) on the two different Travโler configurations. The Direct TV Travโler has a stronger lift mechanism than the Dish Network Travโler does to support the extra weight of the Direct TV head. This is why the Direct TV version of the Travโler always costs more than the Dish Network version does. You can purchase a Direct TV to Dish Network conversion kit for a Direct TV Travโler, but there is no such conversion kit to go from Dish Network to Direct TV because of what I described above.
If I am correct that the Shaw head is equivalent in size/weight to a Dish Network head, then you will not be able to switch to Direct TV with your Shaw Trav'ler base.
โMar-14-2018 12:19 AM
โMar-13-2018 09:38 PM
โMar-13-2018 03:47 PM
โMar-13-2018 05:22 AM
Click here to see where I am
โMar-13-2018 04:30 AM
