โOct-31-2013 07:55 AM
โJan-28-2014 09:31 PM
โDec-01-2013 08:16 PM
โDec-01-2013 07:35 PM
1492 wrote:That did the trick!! I was totally unwilling to format my current USB stick because nearly all 64Gb were full. I scrounged around and found a 2Gb that worked perfectly after formatting. It's in the middle of the channel discovery process as I type. THANKS!BillyW wrote:
Did your unit come with v8 initially? Mine did. I tried the v13 update, and the unit just immediately restarts. It won't actually do the install.
Yes, mine came with v8. No problem updating. Try quick reformatting the USB flash drive w/fat32.
โDec-01-2013 07:09 PM
โDec-01-2013 06:53 PM
BillyW wrote:1492 wrote:
I did update my HW-150PVR to v13 QAM firmware. Very easy and quick. It will add the "cable" option to Signal Type. Though haven't tested it as I'm using this specifically for OTA channels.
BTW, Newegg has both the Homeworx HW-150PVR(w/promo code: 1127BF10) or the iVIEW-3500STBI(w/promo code 1127BF09) for $32.99 w/free ship.
โDec-01-2013 06:51 PM
โDec-01-2013 03:46 PM
โDec-01-2013 11:20 AM
1492 wrote:
Here is the HW-150PVR V13 QAM firmware. I'm not sure why Mediasonic doesn't post it on their own forum site for convenience, as this QAM firmware download link was apparently posted by them on another support forum. You can find firmware update instructions here.
โDec-01-2013 11:11 AM
โDec-01-2013 05:58 AM
โDec-01-2013 12:17 AM
โNov-30-2013 10:32 PM
Tom_M wrote:Apparently unencrypted QAM is no longer supported. They had a firmware update (v12) that added it, but it's been removed. I bought one, hoping to use it with cable and OTA. It doesn't work with cable at all. I'm thinking about returning it, even though otherwise it appears to be a pretty darned good unit.
Unfortunately this will not work for you. It will only record an RF ATSC signal coming from an antenna or channels from unencrypted QAM cable feed.
โNov-24-2013 03:03 PM
โNov-23-2013 05:17 PM
LittleBill wrote:
ok for you guys that have this, will this work with an analog signal?
im not looking for guides or anything. im simply trying to use this with comcact DTA box, which converts the encrypted signal to analog
im simply trying to find a replacement for a vcr. i just need it to be able to record analog stuff on channel 3 or 4, nothing else
it mentions analog pass through but does not mention if it can record that????
