pf32450 wrote:
I will apologize upfront if this has been addressed before. We upgraded to the Dish Network Hopper at home and wanted to know if the main receiver HPR200 (not the Joey) can be taken with us and used while we are camping. We have a extra satellite dish to set-up at the campsite. Also can we just connect to the cable outlet on the side of the TT. Thank you in advance for your assistance. :@
Yes, the Hopper can be taken (it's the only receiver in the house so it must be used). You will have to have the same kind of antenna you have on your house, the Dish 100 antenna PLUS you will need to get a Solo Node Switch like this
Solo Node. You connect to cables from the antenna to the Solo Node and then one cable runs from the Host connection to the Hopper (You have one of these or a Duo Node in your house).
You will be able to feed that one cable into your RV but it's very likely that you will not be able to use your cable connection as it is meant for campground cable and not satellite. There is a possibility, depending upon how your RV is wired you might be able to modify that cabling to work but we would need more details about your coach and how you select between OTA TV and cable TV.
Can't we all just get along?
