weldex model wdrv-7063m back up camera color set up
brianahoyt
I replaced my weldex back up camera (black/white) with a weldex model WDRV-7063M color model and have set it up in my MH but am getting only black and white image. How do I set it up for color. The settings have adjustments for tint,color, contrast, brightness, & sharpness but color does not appear when advancing the bar from left to right. Is there a color mode that has to be set on the camera?
Thanks
Brian
3 REPLIES 3
MrWizard
Moderator
Moderator
did you install a new system both monitor And camera ?
how many leads plug into the monitor 2 or 3
IF its three, one for sound two for video, swap the (2) video leads
I can explain it to you.
1997 F53 Bounder 36s
fcooper
You probably have a camera that does not send a color signal. I think you'll have to replace the camera or live without color.
Fred
Fred & Vicki
St. Augustine, Florida
1492
Moderator
Moderator
Moved from Forum Technical Support
