Wi-Fi / Cell-phone Signal Boosters
hedgehopper
What Wi-Fi / Cell-phone Signal Boosters have worked well for you?
11 REPLIES 11
SKroamcampgroun
we boost is the best! not cheap, but works great if you have at least one bar of service.
https://www.weboost.com/products/connect-rv-65
ktmrfs
another happy weboost customer. the RV system with 75 ohm output, can use longer cable to antenna with way less cable loss than 50 ohm cable.
2011 Keystone Outback 295RE
travisc
Have two weboost car model and rv fixed antennae both work.
Winnebago Access 24V
jorbill2or
Wilson โ€” now called Weboost that I started with 5 years ago. We have found in a terrible location it can be a lifesaver. It can also make a useable un boosted signal not work well. So we make sure we need it . We rarely find a need for it now and leave it off.
We do use a mimo antenna on our two hotspots (Att & Verizon). Best money we have spent.
Bill
Gulfcoast
How well do those Yagi antenna's work Dutch? Range in miles on average?
RV'ing since 1960
Dodge Cummins Diesel
Mega Cab
Jayco Travel Trailer
MrWizard
Moderator
Moderator
I started with a 3G Wilson Sleek (cradle style model) in 2011
Then a Wilson 4G Sleek
And in 2018 I installed a WeBoost 2 piece all carrier model in the RV ,
I've been happy with each one
I can explain it to you.
1997 F53 Bounder 36s
EMD360
I use a Wilson cell phone booster and trucker antenna on the ladder outside and never upgraded to 4g. Itโ€™s an old model but still boosts when there is a signal. Typically 1 bar. I miss the days when I could switch from bars to dBm. I even get a boost from the house to the RV.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
Matt_Colie
Hedge,
You had best make up your mind. WiFi and Cell signals are very different.
I fought with various Wifi ideas and settled on an Alfa device. I got it working only to find that the Wifi I was fighting for was so overloaded that the plan was hopeless.
Then I took to using my cell to create my own hotspot. This was four design levels ago. This was it the 1A days. When I ran out of signal, I went to Wilson Electronics and got a better antenna and a repeater. That worked until 3G. Then came 4G and it had to be upgraded. When 5G is fully implemented, I will probably have to upgrade again.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
3_tons
There are times when they make a difference and times when they dont, mostly dependent on how far away from a tower you areโ€ฆWhen they do work they are the cats meowโ€ฆ
3 tons
Dutch_12078
We've mostly abandoned our Maximum Signal Max Amp cell booster in favor of a directional dual Yagi antenna MIMO pair mounted on top of our Winegard Sensar OTA antenna.
Dutch
2001 GBM Landau 34' Class A
2oldman
C crane long range wifi antenna. Cell phone.. not so much.
Previous booster posts
