โJan-23-2015 12:56 PM
โFeb-08-2015 12:51 PM
โFeb-02-2015 03:51 PM
Bobbo wrote:Jbrowland wrote:
A tiny bit off topic...
So does one need to use a battery disconnect switch if they use their RV say once a month? And if so, it takes only 60 seconds to disconnect my battery manually. Why not do that instead?
Easier.
To disconnect, I push a button.
To manually disconnect, I have to remove step, find wrench, remove cable, replace step.
Easier. And works just as well.
โFeb-02-2015 06:40 AM
โFeb-02-2015 05:04 AM
โFeb-02-2015 03:50 AM
โFeb-01-2015 08:11 PM
โJan-27-2015 08:06 AM
leftys wrote:It does in that it charges batteries.
I could not find a separate "Converter". Does that mean that my "Inverter/Charger" functions also as a Converter?
โJan-27-2015 08:04 AM
โJan-26-2015 11:13 AM
leftys wrote:
After checking the RV, I found the "Inverter/Charger" (Magnum Energy, model MS 2000).
And, to answer the last question, I don't expect the motorhome to be in storage more than 6 weeks at a time, or so.
Thanks for the help!
โJan-26-2015 10:58 AM
โJan-24-2015 07:57 AM
โJan-24-2015 07:22 AM
โJan-24-2015 02:56 AM
โJan-23-2015 07:27 PM
