Battery Problems
justin_powell
I have an issue on my 5th wheel with the batteries. I am green on this and at the risk of looking totally stupid I am asking what is wrong here. They are both 6 volt golf cart batteries which I believe are wired incorrectly. There is an onboard generator also on the RV. I have read to the converter and there is only 6 volts to it. The Generator does start wired as is. Not sure of the connections on the side and the toggle switch there also. I assume the toggle switch is something to do with the shore power. Any advice is greatly appreciated.
http://i153.photobucket.com/albums/s208/jkpowell/Slide1_zpszxaqbdfd.jpg
7 REPLIES 7
justin_powell
Thanks guys. I looked it over and using your advice and diagrams, I have corrected the problem. One wire was wrong. I should be good to go for the year. Appreciate the help fellas.
SlowBro
The only stupid question is the one not asked.
2010 Coachmen Mirada 34BH, class A, 34.75' long, GVWR 22,000 lbs.
2005 Fleetwood Resort TNT 25QB, hybrid, 27.5' long, GVWR 6,600 lbs.
God bless!
Crazy_Ray
google 12volt side of life read and learn
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
Dakota98
Diagram:
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
RoyB
This is how two each 6VDC Batteries are connected in series as compared to how two each 12VDC batteries are connected in parallel..
The end result is 12VDC feeding your trailer...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Golden_HVAC
Looking at the picture, I see several wires connected to the negative wire on battery #2.
There should only be ONE wire connected to the negative battery #2, the wire from +6 of battery #1. All other wires should be connected to +12 wire of battery #2. (except the ground wire, that is connected to battery #1 - wire - ground.)
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Golden_HVAC
The golf cart batteries should be wired in series. So battery #1 ground is to the RV frame, while battery #2 - is connected to battery #1 +6 volts, and battery #2 + is now +12 volts above the RV frame ground wire.
Then the RV converter (45 amps at 12 volts) will charge the pair of batteries much faster than a normal car battery charger.
Good luck,
Fred.
Escapees.com
