Eternabond Roof Edges?
happybooker1
My Keystone roof is one of those membrane roofs that isn't caulked on the sides. Just has the trim screwed in over the edges. I want to Eternabond EVERYTHING to forestall water-leakage.
So.... Any problem with putting Eternabond over this trimmed area? Yes or no?
2008 Tacoma Extended Cab
2009 Keystone Hideout 19FLB
Andersen "No Sway" "No Bounce" WDH
8 REPLIES 8
westend
happybooker1 wrote:
Thanks for the go-aheads. I've Eterbonded my PUP when I had it so I know how great the stuff is & about cleaning beforehand.
This is an '09. Roof membrane looks fine so far. About how long do these types of roofs last?
20 years+ if maintained and not sitting in a desert.
'03 F-250 4x4 CC
happybooker1
Gale_Hawkins
NO but try to make sure you are not taping over trapped water.
LarryJM
NO Installed mine back in early 2008 and now over 6 years later looks like it was done yesterday ... no lifting, etc. I was initially worried about the small contact surface on the top section of the metal insert trim, but it has held beautifully.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
FrankShore
Just make sure that you prep the area first and use a wooden or a metal roller for activating the Eternabond.
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
westend
Me too:
'03 F-250 4x4 CC
Cobra21
I also put my eternabond over the edge of the metal trim...but not onto the vinyl that is in the center of that trim. Has held well for 3 years now.
Brian
dave17352
I put eternabond on all my seams and over the edge into the drip gutter on my lance camper roof. First I was a little concerned about areas lifting in the wind. But I got some dicor 1 tube and put a little bead along any edges that looks suspect. I have taken the rig on a lot of outings and a few thousand miles and it appears to be holding up very well. It is very important to clean the area very well before applying the tape. I can say now I am very happy with the results.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
