โMar-06-2015 06:13 PM
โMar-11-2015 06:31 PM
Dutch_12078 wrote:jmccen58 wrote:
I want to be able to park and not have to move to get propane to run MH....
Take your pick:
Sturgi-Stay
Stay-A-While
Camco Propane Brass Port Kit
โMar-11-2015 01:27 PM
โMar-11-2015 11:30 AM
โMar-11-2015 10:03 AM
โMar-10-2015 04:26 PM
jmccen58 wrote:
Looking to get the connections to hook a 20# "grill" tank to my larger mh tank. Is there one I can buy that hooks into the fill fitting of the mh or do I have to get one that tees into the mh regulator between tank?
โMar-10-2015 07:36 AM
wa8yxm wrote:Extend-A-Stay,bukhrn wrote:
I have an Extend-A-Flow, which is almost identical to an Extend-A-Stay, I use it to run my grill, or you can use it to run the RV off an external, (20lb or any other)tank. Came with a 12' hose to get it a little ways from the RV.
The difference between the Extend-a-flow and the Extend-a-stay is that you can NOT use the Extend-a-Flow to run your RV off a portable tank, , it is designed for trailers that already have portable tanks.
You not only Can, but I have on several occasions, the difference is, the Extend-A-Stay has a specific inlet for the hose from your portable tank, and you can run your grill or other accessories at the same time, With the Extend-A-Flow, once you hook up your portable tank, you can't run anything else off of it.
I had one on my TT, now have a motor home and put the Extend-a-stay on it dang near day 1.
โMar-08-2015 04:50 AM
โMar-07-2015 06:57 PM
โMar-07-2015 03:27 PM
โMar-07-2015 02:24 PM
โMar-07-2015 05:29 AM
โMar-06-2015 06:35 PM
โMar-06-2015 06:30 PM
Porsche or Country Coach!
