Honda Acura MDX
mbrown2130
Does anyone know if you can flat tow a Honda Acura MDX front wheel drive
5 REPLIES 5
Allworth
This may seem like a strange idea, but why don't you ask Acura?
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Bob___Ann
We have a 2012 and it is not towable. I also was told that it is because of the computer control of the AWD.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
RFCN2
We have had two MDX's. We currently have a 2008 and previously had a 2003. You can tow the original model without super handling. So that means up to 2006. From what Acura has told me the computerized super handling is the tow killer.
RFCN2
Country Coach
Jeep Wrangler Unlimited
tatest
If it is a 4-speed OD automatic, you probably could flat tow, using procedures outlined for the CRV, as that transmission was shared across the Accord, CR-V, Element, Pilot, Odyssey and some Acura models. If you do, don't expect warranty coverage for transmission failures.
With respect to other towing issues like odd tire wear and suspension wear, you would be mostly on your own. A good independent alignment shop might be willing to talk about alignment for towing, rather than for optimal handling when driving. If you find a baseplate or towing brackets for it, the manufacture of those parts will put the responsibility on you to make sure that use of what they sell you does not damage your car, but they do the same for all cars.
Tom Test
Itasca Spirit 29B
donn0128
Honda does not make the Acura technically. Acura is a subsidery if Honda.
