The hot water has worked in the past when connected to city water connection
We are out boondocking. The water does not turn on. There is a switch to do gas water heater. How long does that need to be on before the water becomes hot
Does water (hot or cold) run when you open a faucet? It wasn't clear to me if you were having a problem only with the hot water (water pump is working but water not getting hot) or there was no water running at all. If there is no water running it would be an issue with the water pump. Either the switch to activate the pump is not on or the pump isn't getting power or the pump has failed. If you have water in your fresh water tank when you turn the pump switch on you should hear the pump operating. It will operate until a certain pressure has been achieved in the water line and then shut off.
gas switch must be ON. Gas valve must be open.Red light next to switch must come on then go out.You can hear it run. It should take about 20 min to get hot.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
