installing a mud flap
elle8
evening ,,, going fulltime newbie here ,,,, 21 days away ,,,36 ft winnie vista 2011,,, i will be towing a jeep wrangler . is it necessary to have a mud flap on for protection of toad . and if so which kind is best . i see the full rubber ones and then i see the grass looking kind . i am thinking that the grass is lighter , therefore saving on gas . i trying to be very weight conscious . and are they easy to install or should i have it done .
thank you ,,,rickybobby
6 REPLIES 6
wa8yxm
What one person said about the grass/solid ones, if they touch the ground they can throw pebbles up even better than the tires can.
My vote is for the Protect-a-tow... What I use, different name, but identical product, parts are interchangeable they are that identical.
tenbear
I have used a full rubber, full width flap and has worked fine. Just keep it about 4" from the road. I always slow down to about 30 mph, or less, when on a gravel road.
2010 Subaru Impreza Sedan
Clay_L
I used a grass type for ten years and it helps with pebbles a lot.
Both the grass and solid ones are supposed to be installed so that there is about six inches of road clearance. If they are too close to the road pebbles can be thrown up.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
2gypsies1
We drove to Alaska and folks were removing their stiff flaps because of rocks flying and landing at the base of their windshield. We saw some with a layer of rocks laying there. We don't have a flap of any kind and received no damage to our Jeep.
Full-Timed for 16 Years
.... Back in S&B Again
Trackrig
We started towing a 2002 Wrangler behind out DP last year and I can't say that I notice any more rock chips now than it originaly had. A Jeep sits higher than most toads. Because it did need a new headlight, I installed Lexan headlights that wouldn't be broken by a flying rock and they let me install whatever brightness of bulb that I wanted. didn't install any additional mud flaps or rock screens.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Dutch_12078
Full width flaps have been known to kick up road debris in some circumstances, and "grass skirts" can kick up a lot of dust at times. I found that the best solution for keeping our toad cleaner and damage free was installing a "Protect-A-Tow. It even keeps the back of the coach cleaner, and only takes a minute to hook up.
Dutch
2001 GBM Landau 34' Class A
