New rig, Winter camping, everything has gone wrong
No_Stress_Expre
We finally bought our Rig last week (over a month behind schedule we had no choice but to move right in), and thought it was smart to stay local for the next month to educate ourselves about our new home, make sure everything is in good working order and so on.
What we didn't expect...the NC weather to be so cold, the weather to affect the furnace. Then there is the 10 other things that have gone wrong with it that we have to take it back to the dealer to be fixed.
I have years more experience camping than Dan. I camped in the U.P. Michigan every year with an old TT and never had a problem. So, what or why would my furnace (both), stop working when temps dropped below freezing? We weren't using propane, just our 50 amp service. We checked breakers, switches and so on.
Now I'm very concerned that everything is going to freeze and break...black water, gray water, fresh water. The tanks and lines. It's 21 degrees as I'm typing this. We've had to leave the motor home at the campground. I think we are in real trouble. Any help or advice would be much appreciated.
2002 41ft Gulf Stream Friendship
31 REPLIES 31
RVER
YOU better contact your dealer so they can get the list all done in two weeks. Hate to tell you but some dealerships hold units for a month or more to clear up problems. They are good at selling the units but fixing them is not their forte. YOU may have a great dealership but they should have found all the problems BEFORE you stepped into the unit. Most are dogs!!! Hope they are not the ones that are bad, hope you have a great one and they fix it all for you. IF they do not contact the manufacturer immediately so they are notice of a problem with the dealership. BEST of luck with the workkamping, sounds like a lot of fun!!!
2003 Newmar Mountain Aire Vortec engine 35ft
2002 Sunnybrook 34BWTS On site at campground as a seasonal
Chevy Silverado 2500HD with Duramax engine and Allison transmission
Pullrite Superglide Hitch, Prodigy brake controller
S and S Co-Travelers
stvdman
We found electric blankets for the bed to be WONDERFULL. We place it right on top, turn it on 15-20 mins before climbing in, and then turn it on low.. SO NICE!
No_Stress_Expre
It was the cold temps! Heat pumps don't run below 40 or so degrees. We purchased 2 electric heaters that keep everything toasty warm! When it's super cold we have to kick on the furnace to get the chill off but other than that we're good! Thank God! And Thanks everyone for all your help!
Sorry it's been so long for a reply! It was a crazy time! I was a bit overwhelmed and couldn't remember my username or password! Ugh finally remembered today how to get back into the forum! (I won't forget again!LOL!)
Heading to the beach in 2 weeks!(first workamper assignment!) But the fix it list to get done before I leave is endless!
johnwalkerpa1
allen8106 wrote:
Scottiemom wrote:
If you were heating with electric heat pumps, that could be the problem. Heat pumps only work till about 40 degrees. Then they just blow cold air. Nothing wrong with them, that is how they work by design.
Always keep propane when it's cold out.
Dale
I work for an HVAC manufacturer, we design heat pumps to operate down to minus 20f.
I suspect those are bit more advanced than the $600-$1000 units that are popped on the top of most RVs 🙂
As an aside, in good conditions I've been able to squeeze heat out of my RV heat pump down to 30 but that is about it...
koda55
We camp in Pa the beginning of December for 2 weeks in a 42 ft class A.I installed the adapter in the propane line that allows me to use the 20 lb tanks. they last about a day and a half. I just swap them out when needed. I still have my big propane tank to use as needed.
I run my heat pumps when it is above 36 degrees.
CWDoc115
We have on occasion used the engine as a heater. 😮 Learned to pay attention to the tank gauges afterward....:B
hotpepperkid
Dale
I don't know about heat pumps in RV's but the one in my stick house works in cooler weather. The ones in houses have a heat strip for aux heat. Below 37 deg it takes a lot longer for the heat pump to make warm air
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
Rovin__Bones
Another important note about electric heaters; Do NOT use extension cords and do NOT plug them into power strips. Always plug directly into a wall outlet.
Be safe out there. Stay warm.
1983 24' Midas Freeport. Chevy 350 mated to a TH400 transmission on a GM G30 chassis and a spiffy Onan 4kw genset.
!*NEW Blog page*!
Rovin' Bones
Veebyes
Cheap heat. Run out to Walmart & get a couple of ceramic heaters. The trick is not to overload a circuit. Check to see if all outlets are on one circuit. Split the load or run one heater on low power, the other on high. Between the heater specs & circuit breaker rating not hard to firgure out what can & cannot be run together.
More than likely the built in electric heaters are on their own circuit breaker.
In Newfoundland earlier this year we had nights in the 30s & got by without using built in electric heaters or propane furnace. The little portables, one on low, one on high, did the job.
2007 Alpenlite 34RLR
CharlesinGA
You have electrical, use space heaters rather than burning up your propane, burn the park/campground electricity instead. Use a couple, just make sure you put them on separate circuits to spread the load out. Cheap milkhouse heaters or ceramic ones. Cheap at places like Ollies. Just be sure and set them on the floor out in the open, so they are not blowing on anything.
As already noted, put a auto trouble light that uses a regular screw in INCANDESCENT bulb in the service areas that have water fittings. You can still buy 100watt "rough service" bulbs, the government banned regular 100 watt bulbs several years back.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
PastorCharlie
Check your control panel and see if you have a heat pump with an electrical heat supplement... mine does.
Teacher_s_Pet
Re Mark Nemeth: He has a very informative web page from his years as a fulltimer. It's several years old, but still valid. Mark's Fulltime RV Resource
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
Scottiemom
LarryJM wrote:
Dale
I think that's because those have an electric supplemental unit to augment when temps get too low, something RV units don't have because of electrical limitations.
Larry
Quite possibly, Larry. Ours specifically say 40* and at that point, it's like flipping a switch and then the cold air starts!
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Scottiemom
Everything else works. We also ran out of propane. Filling the tank this morning, hoping that will work.
Do you have any clue what would make both stop working suddenly?
The best resource DH and I can think of is RV Boot Camp. It is run by the Escapees RV Club. They are in Livingston, Texas, but they hold the boot camp at most/all of their rallies. You can go to their website and look up info on it. One of their members, Mark Nemeth, is very knowledgeable and writes a column in their magazine. Their boot camp, which covers 3 days I think, covers everything and all the systems you have.
Take a good look and see if you could squeeze something like that in.
Happy Trails!
Dale
Dale Pace
2022 Honda Odyssey
