Outlets not working in trailer
maggiea
Hi, we just bought our very first trailer. It's a 1983 Mallard 20 foot travel trailer. Got an old one to see if we would like taking care of a trailer. The man we bought it from had it parked for 3 years without moving it. We bought a brand new 12v battery and everything turned on as soon as we installed it. But the outlets didn't work. We tried plugging in a little radio to check the outlets and,,,nothing. The bathroom outlet has a ground and we pushed it and it clicked, but still nothing. I've checked everywhere for a manual,, impossible to find. The previous owner has no idea what could have happened. Help please.
30 REPLIES 30
maggiea
tenbear wrote:
Good news! Glad to hear everything works.
Thanks for letting us know.
No, thank you!
tenbear
2010 Subaru Impreza Sedan
maggiea
RoyB wrote:
Here is another electrical block diagram of a typical 30AMP trailer.
Look for something like this on the side of your trailer that houses a PULL OUT long heavy duty extension cord that will have a connection plug on its end that looks like these photos...
Other trailer may have this as a separate 30AMP cable that you must attach to a plug on the side of the trailer that looks like this.
The standard SHORE POWER 30AMP Male Connector that you plug into a camp ground pedestal looks like this.
This will plug into a typical camp ground pedestal socket to provide your trailer 120VAC that looks like this
Camp ground pedestals may also have connections for 30A and 50A cable connections.
Hope some of this may help for what to look for on your trailer. the older trailers may be slightly different then the modern todays trailers. Trailer electrical system must follow safe electrical codes just like a house wiring does. All must be safe to use.
Using a double MALE connector sure doesn't sound like a safe thing to use for me.
Let everyone here know what you are finding so we can help more.
Roy ken
Thank you,,, you guys are awesome. As you may have read, I found the cord. Everything works now. I'm going to print this out!! Thanks again!
maggiea
THANK YOU ALL VERY MUCH!! I found the cord and everything worked just as you all said it would. Even the 30 year old ac & heater works like brand new! Thank you for the heads up on the "suicide cord".. yikes! Thanks again lifesavers... onto my next questions 🙂
maggiea
maggiea wrote:
relaxin wrote:
maggiea wrote:
Also, am I using the words "shore line" correctly? Is it just an extension cord you run from an exterior source? The trailer also has 2 outlets on the outside of it, but it looks like I need a cord with 2 'male' ends. Does that make sense? THANKS EVERYONE!
NOOOOOOOOOOOO!!!!!!!!!
:S
your trailer should have a little hatch somewhere that has the cord rolled up inside, pull it out, you will need a 30 to 15 adapter (available at an rv dealer and a few other places) to plug it in to the side of your house
I FOUND IT!! IT ALL WORKS NOW!! THANK YOU! 🙂
oK, I will look again. Thanks much!!
tenbear
Good info JLTN_James. Should be required reading for all newbees.
JLTN_James
SAFETY WARNING: NEVER, EVER, consider using a double ended male electrical cord! These are commonly called "suicide" cords for a reason. When you plug one end in, the other end has exposed, energized contacts that can and will electrocute anybody or anything who comes in contact with them. Electricity doesn't care who you are or what you are doing. It's an equal-opportunity killer.
Some terminology to keep in mind:
Voltage = the electrical force that makes current flow in a conductor. The unit is Volts (V). Think water pressure in a pipe.
Current = the amount of electrical energy flowing in a conductor. The unit is Ampere Amps or A). Think volume of water flowing through a pipe.
Alternating Current (ac) = With out getting too technical, ac power "flip-flops". If you were to look at the voltage on a graph, it would make a sine-wave at 60Hz (cycles per second). Your house operates on alternating current.
Direct Current (dc) - Electrical current where the voltage remains the same. If you were to look at the voltage on a graph, it would be a straigh, horizontal line. Your car battery is direct current.
Converter = An electrical device that takes 120Vac in and produces 12Vdc out.
Inverter = An electrical device that takes 12Vdc in and produces 120Vac out.
Shore Cable = The power cord that provides power into your trailer from an external source such as the campground power pedistal or household electrical outlet. The term "shore cable" comes from the fact that ships in port will use cable to bring in electrical power from the shore facilities.
Adapter = a device used to adapt one electrical connection to another without changing the type of electrical power utilized.
As previously stated, your trailer has a shore cable somewhere. It will be coiled up inside, but accessible from the exterior through either a round or rectangular hatch. Either hatch will have an inverted "U" door that the cord will pass through with the large hatch closed. See the two following photos:
Your hatch may or may not have the sticker shown. They tend to wear off after a few years.
The end of the shore cable will have a TT-30 plug (for the trailer age/size described). It should look something like this.
This plug operates at 120Vac, same voltage as your household outlets. A difference is that it is rated to carry 30 amps, and as such, it has a different plug. Obviously this won't fit the outlets at home which should be a NEMA 5-15 or 5-20 designation; both are similar and most people don't notice the difference, the 5-20 version has the extra horizontal slot as shown below:
You need an ADAPTER to plug the shore cable into your household outlet. The least expensive option is the stubby adapter that is about 2" long and about the same diameter as the TT-30 plug. It has a household-type male plug rated for 15 amps and a female TT-30 receptacle on the other side. You can see my stubby adapter on the shore cord below. Mine is a 90-degree one, most common is the staight through version with the male plug side opposite of the female side.
The upgraded adapter is basically the same but has a length of cord between the two. This is commonly called a "dog-bone" adapter. The benefit is that the dog-bone adapter separates the two connection points so heat can dissapate better. (I'm actually suprised RoyB didn't include a photo in his post.) I apologize that I don't have a good photo of one of them. With either adapter, you are limited by the household-type plug. This means that you may not be able to run everything in the trailer at the same time such as a microwave, air conditioner, electric water heater, electric space heater, etc.
Inside the trailer, the shore cord goes into a small electrical box with circuit breakers, they are same as the ones in your house. From there, the 120Vac power is fed to the household outlets, the converter, microwave, air conditioner, and other 120Vac powered appliances. The refridgerator often uses two or three sources of energy such as 120Vac, 12Vdc, or propane. The converter may also be located in the same box and you may see automotive type fuses on one side for the 12Vdc outputs.
Power from the converter is at 12Vdc (actually closer to 13.2Vdc-13.4Vdc). This power feeds things such as the water pump, lights, furnace fan. It also connects to your battery so you can use these items when NOT connected to 120Vac power through the shore cable.
Unfortunately, without an inverter and a stout battery bank, you can't use the household electrical outlets without the shore cord plugged into a source. Using an inverter is a whole different set of lessons...
As the OP mentioned, they found the outside receptacle. This is for plugging in lights, radio, or other small 120Vac powered items and not for bringing power into the trailer.
Good luck!
2004 Toyota Tundra SR5 (V8, 4WD, TP, TRD)
2005 Fleetwod Allegance with axle flip
Honeywell 2000i Generator
Me, DW, DS, DD, & Chicken-Dog
RoyB
Roy ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
maggiea
tenbear wrote:
My motorhome, and both previous trailers that I owned, had a power cord inside a compartment. This power cord has a 30 Amp plug on it. You will need an adapter to plug this into a home power receptacle (shore power). Do NOT use a power cord with 2 male connectors to power the trailer. You may have some other power connecter that requires an adapter of some sort.
The converter is an electrical box that converts the 120vac power to 12vdc that charges the battery and supplies 12 volt power to the lights and other 12 volt things in the trailer when you are plugged into shore power.
Oh wow,,,ok. I haven't been able to find any cords at all. I'm going to have to take this adapter to Camping World and see what they suggest. Thank you!
maggiea
:S
maggiea
:S
Oh ok, i'll look for the cord. I thought we went through everything, i'll look again. THANK YOU!
Bucky_Badger
maggiea wrote:
Thank you all. I am beyond a novice and tried to look up some of your terms. So, no, I didn't know you had to be plugged into a shore line,,duh,, I thought the 12v batt would be sufficient. And, no it doesn't appear by the nice schematic Old Biscuit posted, that there is an inverter. There was a very large 3-prong adapter. Easy enough to plug it in, but it appears that I need an extension cord with 'spread apart' prongs to plug into this thing. Many of you have said to just plug a household cord into the trailer, but honestly, I cannot find where to plug a shore line into. Also, is the large plug I found a converter... I looked it up and several different photos show up, including some that look like the adapter i found. Thank you all so much again! Sorry for the delay,, work has firewalls on all our computers and has you blocked.
The camper will have a very small door, usually on the....well call it the drivers side..... that has a cord in it..the door is usually round and about 3 to 4 inches big...pull the cord out and use the adapter to use a house outlet
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
tenbear
relaxin
:S
Relaxin, hikin, canoin, enjoyin life
headin down the road with a 29' reflection, canoe, camera, & hammock. 2022 GMC extended cab 6.6 litre gasser.
Rug rats grown and gone, just me and my beautiful little lady.
