Fizz wrote:
Cracked lino means it had a hard winter when the lino shrank and cracked, nothing more. My TT is in great shape but we had a -40C day a few year ago and the lino cracked.
Ditto. There was an especially cold winter a few years ago and there were a lot more cracked/split sheet flooring cases in Canada and the US. It's entirely related to low temps. The splits are often at floor vents and other penetrations that cause stress points.
New flooring could be due to cracked flooring or if laminate planks, could be an upgrade. I'd stay away from laminate that uses glued joints Also, laminate requires a proper expansion joint around the perimeter.
One of the most critical things about used RVs is water intrusion and failed caulking not redone. If owners have used an RV a lot in cold weather, inadequate venting of moisture on the inside will cause condensation within walls and the ceiling cavity and can lead to severe damage.
I would consider hiring a reputable RV tech and getting an inspection done. Personally, I would not use a tech from a dealer and would go to an independent RV repair shop. A couple hundred $$ could save you a fortune down the road.
