rack size for batteries
ScottyP
Are the rack they use for batteries in Rv's standard sizes? Here is my issue. I bought an 06 Gulfstream Ultra. It has a rack to hold two deep cell batteries (but it only has one 12V at the moment). In reading the forums, I might want to purchase 2, 6V golf cart batteries, however, I am not sure they will fit. I measure my rack and it is 14 1/4 inches. Most golf cart batteries I am seeing on line have a listed measurement of 7.13 inches.
So my question--can my rack handle two of this six volts? How tight can these things be? Are most racks designed to handle these standard battery sizes? Thanks for any help
5 REPLIES 5
RoyB
Here is a TROJAN T105 spec sheet which shows the case dimensions
Usually the kicker with the 6V GC2 batteries is the height - They are alot taller than a standard battery...
X2 on marking cables. It is so easy to get them reversed. If that happens then you will looking for fuses to replace. Use TAPE and mark each lead a "+" or a "-" depending which battery terminal they come from...
Also don't forget the 6V golf cart batteries have to be conneced in series to get 12VDC out of them
just my thoughts
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Sprig
ScottyP wrote:
Are the rack they use for batteries in Rv's standard sizes? ... I measure my rack and it is 14 1/4 inches. Most golf cart batteries I am seeing on line have a listed measurement of 7.13 inches.
So my question-...
Let me cut to the chase scene.
The TOP and BOTTOM measurement physically is not the same on the battery.
Both dimensions are important if you want to have a battery bank.
My gut instinct tells me that you have nothing to worry about; yet I have seen even more common things not work in particular applications.
Veebyes
Shove as much amperage as you can get in the space available. 2 6V, 2 grp 24s, 2 grp 27s, 2 grp 31s, a single 4D, a single 8D. Whatever uses the space best.
2007 Alpenlite 34RLR
Adam-12
Skipnchar has some good advice. Use some spacers. You can make your own with plastic cut up PVC pipe or whatever you find at the hardware store. Use your imagination. I'll add you can also use a nylon tie down strap to to hold down the battery box.
For my friend, I simply cut off his existing metal battery rack and welded on a custom sized one to his specific needs. Simple angle iron is your friend. You can find a welder to do that very simple and effective mod, if need be.
I'd do it for you for a beer and pizza, but you and I live at two different coast lines.
Silverado 2500HD Duramax DIESEL/4x4/CC/Z71:W
31' Travel Trailer
2 Honda EU2000i's (parallel)
ICOM 7000
Random wire, dipoles, verticals
Hunting/Fishing gear
Welding/Fabricator
Life endowment member NRA
:B :B
skipnchar
The foot print of a Trojan T 105 (the most popular 6 volt battery) is exactly the same as a standard group 24 battery (12 volt). It is about 2" taller however. It's tremendous POWER and staying power are achieved with plastic spacers between the SOLID lead plates as opposed to cardboard spacers between waffle plates in most Deep Cycle batteries.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
