Jul-07-2015 07:40 AM
Jul-12-2015 08:50 PM
Jul-12-2015 07:16 PM
Jul-12-2015 04:22 PM
2112 wrote:Happy.Camper wrote:YES!
If I do the "test" jack them up, shake the wheel to see if loose, then turn wheel to see if it grinds, and all is good, is that sufficiant ?
This and a touch temp test. Tow it about 20 miles at ~60 mph, pull over and touch each hub. If they don't feel hot to the touch you are good to go. Considering how little you tow you may never need to repack your bearings.
Jul-12-2015 05:10 AM
Jul-12-2015 05:05 AM
Jul-12-2015 03:41 AM
Charlie D. wrote:Grit dog wrote:
If it's impossible to get grease to the inner bearings without disassembly or an easy lube ( that's where the spindle is line bored carrying grease to in between the 2 bearings, right? Help the clueless), then how can one push out the grease seal on a hub with bearing buddy's..
The spindle is not line bored it is drilled. The EZ Lube system does not inject grease between the 2 bearings. It is injected between the back of the bearing and the lip seal. This seems to be what creates the issue with blowing the seal out.
I hand pack because I do not want to take a chance of blowing out the seal and I do not want the entire cavity full of grease. Just my opinion. Op, any auto repair shop can repack your bearings. Call a couple for price. May be cheaper and quicker than a RV dealer.
Jul-11-2015 05:54 PM
Jul-10-2015 10:21 PM
Grit dog wrote:
Well jfkmk, you got me there. I'm clueless...........
Quick question though. If it's impossible to get grease to the inner bearings without disassembly or an easy lube ( that's where the spindle is line bored carrying grease to in between the 2 bearings, right? Help the clueless), then how can one push out the grease seal on a hub with bearing buddy's?
I'll help you out there. The grease can migrate through the outer bearing with very little pressure. In fact if you hold the grease gun flat against the outer bearing face, if there's room, you can push grease through the outer bearing no problem.
But I'm probably lying.
Jul-10-2015 11:11 AM
Jul-10-2015 07:47 AM
Jul-09-2015 08:23 PM
Grit dog wrote:
Jfkmk
Well the op got more than he bargained for in this thread which is par for the course here.
I thought punk kids argued more on the innerwebs but based on this site, the gramps got em beat!
I wasn't saying you don't know how to take care of your trailer and I never said one should never disassemble and re pack them.
What you missed was me suggesting periodic maint.
I'm not an AARP member yet so you got some years of grease monkeying on me but after 25 years of driving/towing/ mechanic work/fleet maint I'm pretty confident in my methods as well.
FYI you don't need to "pack" the bearings when adding grease to get it in there.
Bearing buddies work better I think than just popping the cap and adding grease but they open one up to blowing out the rear seal with too much grease.
When you lay a bunch of grease in around the castle nut and toss th cap back on, it gets to both bearings after some driving. If it didn't, you'd see that fresh blob of grease sitting there when you popped the cap again after those road trips. Period.
Like my first post I told the op there is no one set answer.
Jul-09-2015 11:44 AM
:E :h Sorry that has to part of what I can only call the " put a couple of squirts of grease" to "top them up" crazy idea. Unless you take the bearing out and press the grease into the rollers there is no way the grease will magically "flow" from one side of the bearing to the other. If that were the case then all the grease would flow out of the bearings since they are open on both sides.
Again sorry but that idea can only at best be called HOGWASH and IMO clearly shows your TOTAL LACK of understanding the axles, hubs, and drums used on TT and how they are constructed. There is a HUGE CAVITY between the spindle and the drum between the two bearings whose volume is close to 1/3 top 1/2 tube of grease and is initially empty after a tear down, cleaning, and bearing repack. I know this size because that is the amount of grease you have to add to an EZ lube axle via the zerk fitting after a complete tear down and repack to get the grease to start showing up around the washer and castle nut on the end of the spindle. So even if the grease "
IMMACULATELY MIGRATES" from one side of say the outside bearing to the indside of that bearing it would simply fall into that cavity and never reach the inner bearing.
Maybe not, but some of your responses and ideas have at least IMHO clearly demonstrated there are still some crazy and BAD ideas and answers floating around.
Jul-09-2015 08:37 AM
Jul-09-2015 05:26 AM
Jul-08-2015 10:25 PM
Grit dog wrote:LarryJM wrote:jfkmk wrote:Grit dog wrote:
There is not a set answer here. Pop the caps and see how the grease looks. If it's all grey (metallic) and runny (compared to fresh grease) then it's time. Easy to check.
If the grease is still close to original color and not degraded then top it off with a few squirts and let er rip for 3 more years!
I disagree that sitting and not being used does any sort of real degradation to the bearings. Doesn't even make sense. That's like saying the grease goes bad in the bucket of tube after 2 years.
Just bought an 05 or 06 Sno machine trailer last year. Had like no miles on it. PO claimed 500 mi and I believe it.
Hubs/ bearings were never touched. Put a couple squirts of grease in each wheel to top them up and put maybe only 1500 mi on it since. No issues.
Never even took the hubs off my old sled trailer in close to 10 years and probably 15-20k miles, guessing. Just kept them greased.
RnR the hearings before heading to AK and re packed the hubs. Bearings were still fine and proceeded to put another 4-5kmi on it, loaded to the gills. No problems.
What??? Where on earth are you going to " put a couple of squirts of grease" to "top them up"? The OP never stated he has EZ Lube and since it's not a boat trailer he probably doesn't have Bearing Buddy's. Even with EZ Lube there is a procedure to follow, you don't just "top them up". The OP doesn't really have a clue about bearing maintenance (that's why he is asking), why would you tell him something so blatantly wrong?
You took the words right out of my mouth on this terrible advice of "put a couple of squirts of grease" to "top them up". While the OP has admitted not knowing much about bearing maintenance and has wisely asked for advice I'm amazed at the folks that are willing to jump in and give blatantly "BAD" advice and demonstrating they know as little or less than the OP that has at least wisely asked for advice.
For the OP as mentioned a lot of "book" answers say every year or so here is my take on this. First I use a moly fortified grease that meets the specs for the particular axle. IMO these EZ-Lube or equilivant axles at least for TT is an interesting idea in search of a reasonable application and TTs is not one of them. Reason is that it takes "A LOT OF GREASE" and as mentioned a very detailed and specific procedure to do it correctly. Also, when you do finally tear things down that is a lot of grease to get rid of and then reapply. My recommendation is to forget trying to use the EZ-Lube or equilivant feature and do a regular tear down and repack. I see no real reason to do this every year and my limit is around 20K miles total or 5 years which ever comes first except for the first one and that should be done as soon a possible so you have a good known starting point. These "personal" limits is something I have just developed a "FEEL FOR" over the 50+ years that I have been doing my own bearing maintenance on all my curent and past trailer and vehicles.
Larry
Well you 2 keyboard jockeys are obviously the trailer bearing authorities, lol. (Like the weight police and them guys that weigh every ounce of they're putting on the truck including whether him and the ole lady had their BM for the day yet!)
Since ole Larry goes 5 years and 20k before looking at the bearings then that is what you should do! Oh wait, that sounds like worse advice than inspecting and periodically adding grease......... Whoever said that!
As long a you got a "feel" for it we will all be fine!
That's why I love this forum. It's pure entertainment!
Oh and if you can't figure out how to add grease to a trailer wheel without a bearing buddy or easy lube then you shouldn't be giving out advice!
