May-28-2013 06:27 PM
Jun-03-2013 06:04 PM
Allworth wrote:
These are the same people who insist that you MUST use only the most expensive hitch, the most expensive tires, the most expensive dually, the most expensive wheel chocks, the most expensive.......
Do we see a trend here?
Jun-03-2013 04:25 PM
Jun-03-2013 12:52 PM
mark5w wrote:Gau 8 wrote:Francesca Knowles wrote:
TPMS's are for people that can't/won't check the air pressure in their vehicles' tires on a routine basis, as used to be the norm.
Unfortunately, those are the same people that won't pay any attention to the TPMS either, so one has to wonder what the heck the point is.
Wow. I am speechless! Must be nice to have it all figured out.
When you have a small travel trailer like Francesca you really don't need one I guess. :S
Jun-03-2013 11:03 AM
Jun-03-2013 10:33 AM
MotorPro wrote:
Some people make it sound like if you don't have one you committing suicide. The fact is people drove and towed for over 100 years with out one. A majority of 18 weelers don't have them.With out one you should check your tires before every trip. Are they nesseary? No,but they do make life easier and give that extra peace of mind.
May-31-2013 07:47 PM
May-31-2013 06:50 PM
May-31-2013 06:03 PM
May-31-2013 04:11 PM
wanderingbob wrote:
No doubt a person that has bought one will think he needed it more than he needed the money . Do you need one ? Who knows ? Put the $250 in one hand and the TPMS in the other ,which hand do ya like the best .
To say one of dem thangs saved your bacon just means that you were not eyeballing and checking your tires . All they do is tell you that the pressure is low , thats all . They do not tell ya that the tire will not blow for hundreds of other reasons . It all boils down to how much money and how many gadgets does it take to make you feel safe !
May-31-2013 01:04 PM
Bobbo wrote:THAT edit puts a totally different perspective on your comment! And we are now in total agreement!:Bkaydeejay wrote:Bobbo wrote:If you have a TPMS that has proven to be accurate, why do you need to check the tires with a pressure gauge? You can check ALL tire pressures at a glance on the TPMS display.
TPMS is peace of mind. Of course,if you don't have a TPMS that means you need to check the tire pressure on a regular basis with a tire gauge. Also, you can bump each tire with a hammer for a rough idea of tire pressure. When I got a nail in one of my duallys, the hammer test is how I found out it was losing pressure. If one of the tires loses 10 psi, you can really tell the difference in sound long before the tire goes flat. But you STILL need to use a tire gauge on a regular basis.
I checked mine regularly when I first got my TST system, but when the readouts were consistently within 1psi of the gauge reading I figured that was good enough.
I was not clear in my message. I went back to add if you don't have a TPMS. I readily acknowledge that the red letters in the quote above were not in the message you quoted.
May-31-2013 12:09 PM
May-31-2013 11:19 AM
May-31-2013 09:43 AM
TPMS is peace of mind. Of course, that means you need to check the tire pressure on a regular basis with a tire gauge. Also, you can bump each tire with a hammer for a rough idea of tire pressure. When I got a nail in one of my duallys, the hammer test is how I found out it was losing pressure. If one of the tires loses 10 psi, you can really tell the difference in sound long before the tire goes flat. But you STILL need to use a tire gauge on a regular basis.
May-31-2013 08:38 AM
