Oct-05-2018 08:36 PM
Oct-06-2018 06:37 AM
JoshuaH wrote:
I was wondering, is there any reason why I can't use compressed air to blow out all the water in the lines? I have an air compressor, wouldn't be hard to make an adapter that will hook to the water connection.
Thanks!
Oct-06-2018 06:30 AM
Oct-06-2018 05:39 AM
Oct-06-2018 04:14 AM
JaxDad wrote:
That could only be an issue if you don’t blow the lines out properly. I did an experiment a few years back for sceptical friend to show him how well it works. I took a 100’ coil of clear fuel hose and hooked to to tap, then with it standing vertically hooked it to the compressor with the regulator set to 50 psi. There wasn’t a drop left in the line.
The issue arises when someone uses a very small compressor that can’t maintain the required pressure for very long, or just doesn’t perform the task correctly.
Oct-06-2018 04:05 AM
LarryJM wrote:
Biggest issue with just blowing out the lines is that if your system has a low run of pipe you could end up with water in it after blowing out the lines since residual water could drain and collect in that low section, freeze and cause an issue.
Larry
JoshuaH wrote:
Thanks. We like to camp off grid in the winter, after pricing RV antifreeze I got to thinking I'm going to be spending a lot of money each time we go, would save some money to just blow out the lines.
Oct-06-2018 02:48 AM
Oct-06-2018 02:24 AM
I figured there was no reason I couldn't do it this way but wanted to make sure I wasn't missing something.
Oct-05-2018 09:16 PM
Oct-05-2018 09:08 PM
Oct-05-2018 08:51 PM
