โOct-10-2013 07:50 AM
โJun-02-2014 04:44 AM
vmacky wrote:
So thanks to everyone from previous responses, went with Ford F350 diesel as my new tow vehicle and made the first trip. Quickly realized that the super duty was much needed and made the 4 hour trip pleasurable.
โJun-02-2014 02:53 AM
โNov-03-2013 08:25 AM
โOct-16-2013 04:34 PM
โOct-14-2013 08:08 AM
โOct-14-2013 07:03 AM
Hybridhunter wrote:lbrjet wrote:
1/3 of the TW does not get transferred to the trailer, show me your weight tickets. Typically it is more like 15-20%. There are numerous examples of three scale weightings on this forum and I have never seen 1/3. It is usually less than 20%.
I stated 1/3 of the weight removed from the rear axle goes rearward to the trailer. I concur with 15-20% of gross tongue weight as an accurate number. I have spreadsheets for a couple trailers that show in between those, shank length, TV length, and trailer length determining actual.
โOct-13-2013 11:05 PM
โOct-13-2013 08:51 PM
โOct-13-2013 03:17 PM
AlmostAnOldGuy wrote:
Snip...
As far as the trucks tow weighting the manufacturer assumes you are pulling a flatbed when making those numbers. A travel trailer is different, primarily with more tongue weight.
Good luck,
Stu
โOct-12-2013 09:34 PM
โOct-12-2013 05:52 PM
โOct-12-2013 05:35 PM
Hybridhunter wrote:
How about you toss 13% out the window? Your assumptions are muddying the discussion. And going 70 mph, wow, that sure is wild.(eyes rolling....) I imagine i would have found out the hard way with nearly 20000 miles on the tires, always going 70. Same with the truck.
Tongue weight can be managed, at 11.5% from the OEM, keeping that around there can yield a safe, nice towing combo. End of story.
And todays F150 is a different truck than even 5 years ago, it's no miracle truck, but it is fine at 100% GVWR.
One obviously does not shoot for 13% tongue weight, just because you day so, if it overloads their truck. I should not have to even post that.
To the OP, can you weigh it? Tweak the WDH to get your axle weights under and see what is what. Your setup can be managed to be legal and safe based on tongue weight, passenger load, and WDH settings. Only you can decide if it tows to your satisfaction and works for you.
โOct-12-2013 05:21 PM
โOct-12-2013 05:17 PM
