IF they make a kit for your truck, after it is installed and working properly you can tow it.
However, unless you can find an application chart on the manufacturer's website you will have to ask them if they make such a kit.
I doubt in the average man-on-the-street would have that information.
I sure don't!
OR, you can take the time to get under the truck, remove the driveshaft from the differential yoke, put tape around the bearing caps so the don't get lost, and tie the shaft up to the body with baling wire.
I used to do that with a Datsun diesel pickup. It took about five minutes to disconnect, and about 5 minutes to put it back. Of course, I was a LOT younger back then!
CM1, USN (RET)
2017 Jayco TT
