โJun-10-2021 10:07 AM
โJun-11-2021 07:42 PM
wanderingaimlessly wrote:
No, I'm not suggesting running two AC units off of a 2000 watt genny, but you can run a single little 9000 btuh AC on the small genny, which is not normally doable with the 15000 unit.
โJun-11-2021 04:24 PM
โJun-11-2021 01:01 PM
valhalla360 wrote:wanderingaimlessly wrote:valhalla360 wrote:wanderingaimlessly wrote:
The only thing I would question over the "bigger is better" folks is, how do you camp? If you frequently dry camp, you may find that a supplemental 9k to 11k btuh unit may allow you to run a little 2000 watt genny to power the slightly smaller ac unit on those occasions you dont have a shore power tap available.
You aren't running 2 air/con units off a 2000 generator.
If you plan to run the air/con off grid, better to jump up to a 3000w generator.
Still better to jump up to a suitable generator (up around 3000w) but a 2000w can usually work if you use a soft start and make sure nothing else is running...but that applies even if you put in a small air/con. It's the startup load that is the challenge for undersized generators.
โJun-11-2021 08:54 AM
โJun-11-2021 05:51 AM
โJun-11-2021 04:38 AM
โJun-11-2021 04:04 AM
โJun-11-2021 04:01 AM
Super_Dave wrote:
If it is just for the bedroom, a polar cub 9 or 11 would be more than enough and possibly quiet enough to sleep with while running.
โJun-11-2021 03:59 AM
โJun-10-2021 06:28 PM
โJun-10-2021 06:27 PM
kfp673 wrote:
Thanks all! The unit is pre-wired for electric but not ducting. Should have mentioned that originally. So it would be a direct vent for the second. We have a front bathroom which currently has a vent and the bedroom has a vent. The factory vents can only be aimed not closed. So I intend to replace those with vents that can be closed helping cool the main living space and the bunk room more and then open all when we are on 30amp and can only run a single. Most of our camping is <90 F but being east coast it is often very humid. Anyway, sounds like most would for 15k for the bedroom. Maybe I add a box fan during the day to blow bedroom air out into the living space to help.
Thanks again all!
โJun-10-2021 05:22 PM
โJun-10-2021 04:39 PM
โJun-10-2021 03:52 PM
