โMar-24-2014 10:54 AM
โMar-26-2014 08:26 AM
โMar-26-2014 07:54 AM
โMar-26-2014 07:07 AM
โMar-24-2014 09:38 PM
wgriswold wrote:uintafly wrote:
Yep, I think I will be fine with that. But the manual is a little fuzzy on how much if any to adjust the angle bolt. Has anyone adjusted one before?
IIRC the angle bolt just snugs up against the washers and there is no further adjustment.
I called the factory and was told that the bars do not need to be parallel to the trailer frame. In a sharp turn I would make sure that the end of he bar does not contact the trailer if the bar is not parallel.
โMar-24-2014 03:59 PM
CND SuperCrew wrote:
Another note, ensure that your TT is sitting level and measure from ground to inside of coupler. Then you can also adjust the height of the ball to 0.5-1" higher on the shank. You may have to flip the shank to accommodate this.
โMar-24-2014 03:46 PM
โMar-24-2014 03:41 PM
โMar-24-2014 03:32 PM
โMar-24-2014 01:43 PM
uintafly wrote:Ron3rd wrote:
If your bars are not parallel, I doubt adding a washer will do anything. All that does is puts more tension on the bars and transfers more weight to the front, it does not change the angle of the bars. Check the manual first, it sounds like it's not set up right and you need to move the head up or down or the L-brackets on the trailer up or down.
You are correct. I probably didn't explain myself well. I am moving the brackets to make the bars parallel, but and I have a feeling that will not provide enough distribution, which will cause me to change the head angle to create the same distribution.
โMar-24-2014 01:24 PM
wgriswold wrote:
The manual says that lowering the bracket one hole down is the same as removing one washer. So adding one washer while moving the bracket one hole down will deep the same weight distribution.
โMar-24-2014 01:23 PM
โMar-24-2014 01:12 PM
โMar-24-2014 12:55 PM
โMar-24-2014 12:12 PM
