โJul-06-2020 06:48 PM
โApr-13-2021 12:51 PM
โJul-09-2020 05:43 PM
โJul-09-2020 02:23 PM
โJul-09-2020 12:57 PM
Lynnmor wrote:
What Ford truck do you have? Here is the information from a 2020 F350 owners manual:
When hooking-up a trailer using a weight-distributing hitch, always use the following procedure:
1.Park the loaded vehicle, without the trailer, on a level surface.
2.Measure the height to the top of your vehicle's front wheel opening on the fender. This is H1.
3.Attach the loaded trailer to your vehicle without the weight-distributing bars connected.
4.Measure the height to the top of your vehicle's front wheel opening on the fender a second time. This is H2.
5.Install and adjust the tension in the weight-distributing bars so that the height of your vehicle's front wheel opening on the fender is approximately halfway between H1 and H2.
6.Check that the trailer is level or slightly nose down toward your vehicle. If not,adjust the ball height accordingly and repeat Steps 2-6.
โJul-09-2020 05:21 AM
โJul-08-2020 06:37 AM
โJul-07-2020 08:10 PM
โJul-07-2020 08:03 PM
โJul-07-2020 06:35 AM
Rvinnewbury wrote:
he trailer. Set up and hook up were worlds easier then the ProPride. As for weight distribution, I was able to get my front axles within 0.5 inches of unloaded, which is Ford's spec.
