โOct-12-2015 06:23 PM
โAug-30-2018 05:08 PM
โAug-30-2018 03:57 PM
โAug-30-2018 12:03 PM
โAug-24-2016 04:34 PM
โNov-02-2015 09:58 AM
ajriding wrote:buta4 wrote:
Wouldn't recalibration of the speedometer/odometer be necessary in some of these cases? Just a thought.
Few would care. I have gone bigger on my truck, and just deal with it and know what the real speed is. The numbers are rarely more than 1.5-2 off. My trucks speedometer is off but somehow the mile counter is spot on.
You can change the gear in the speedometer to match.
โNov-02-2015 07:01 AM
โNov-02-2015 06:46 AM
โNov-02-2015 05:32 AM
โNov-01-2015 05:06 PM
โOct-28-2015 10:34 AM
ajriding wrote:
Thanks, Pianotuna, good reply. It brings up a thought. Why not just change the gearing in the rear dif?
Larger tires are less efficient, but the drop in rpm overcomes this, but keeping small tires and changing the gearing will drop the rpm and keep the tires smallโฆ
I actually want larger tires to "look" better also, so may stick with tire changes. Ground clearance is a plus.
I have had oversize tires on my truck before and the mileage dropped off considerably, but that engine was having to work.
Interesting about the 215/85-16. I have heard that more narrow tires are more efficient than wide tires, so even a large diameter tire that is narrow will be better than a wide tire of smaller diameter. Any experience anyone?
โOct-28-2015 09:40 AM
โOct-24-2015 05:33 PM
โOct-23-2015 07:36 PM
โOct-23-2015 05:26 AM
