Bullseye dent in fiberglass rv
Mickeyfan0805
While washing our rig yesterday, I discovered a small dent in the fiberglass. The center of the dent is quite small, with concentric rings, like that of a 'bullseye' formation, extending out to about the size of a nickel. If it were up front or on the side I'd expect a small stone. Being on the rear, I'm not sure what happened. It honestly looks as though it was shot with a BB-gun.
It is not especially apparent, but I'm a bit concerned about water intrusion leading to delamination. Anything I can do to try to repair, or at least secure, this dent so that it doesn't cause increased damage?
15 REPLIES 15
RobWNY
It probably WAS shot with a BB gun. Is the fiberglass cracked? I'd probably go to an automotive store and buy a spray can of clear coat and put on several layers and call it good. Another option is to fill it with bondo, sand it smooth, prime it, paint it, and cover it with graphics. Unless you're good at fiberglass repair or want to spend a lot of money to have it repaired those are the options I can think of.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
