Cam lock spins
UncleAl
Some cam locks on my 2001 Winnebago Itasca Spirit have rounded out their holes so the lock cylinder just spins in the hole. The previous owner just cranked the cylinder nut tighter causing the fibreglass to crack. The compartment door is just foam fiberglass sandwich, so the only thing that ever gave the hole any substance is the thin fibreglass.
Anyone have any experience repairing their cam lock holes?
10 REPLIES 10
wnjj
wa8yxm wrote:
Just remembered something.. I think I've seen these with 4 teeth. (more teath better)
cam lock washer bites into wood
That same site has plates as well:
Cam lock plates
wa8yxm
Bobbo
Some camlocks take circular holes. Other camlocks take double-d holes. If the camlock needs a double-d hole but only has a large circular hole and the gasket material that was holding it fails, you need a more secure mounting.
Bobbo and Lin
JimK-NY
It seems that my camlocks were installed by drilling circular holes. The gasket material has been enough to hold the locks in place. I don't see the need for any modifications to the compartment doors.
UncleAl
Thank you all.
I like the aluminum plate on the inside idea!
StarkNaked
Here is an example of a replacement lock that shows the correct hole shape, and it also comes with an metal spiked "washer" to lock the cylinder in place.
https://www.ultimatesecuritydevices.com/Ultimate-Security-Devices--Extra-long-weather-resistant-2-18...
QCMan
Nomad III
Nomad III
JimK-NY wrote:
I have no idea what you mean by rounded out camlock holes. My camlock barrels are circular and fit into circular holes drilled through the compartment doors. Rubber gaskets/washers prevent the lock mechanisms from spinning in the holes.
If the gasket/washers are missing you can replace them or you could even use star washers which would bite into the compartment doors and prevent the locks from spinning.
Most cam locks are in a double d hole. I would agree that the easiest way is to use a piece of aluminum with a double d hole to back up the inside but I would use double stick film like indoor/outdoor carpet tape. Weatherproof and has lots of holding power.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
JimK-NY
1995brave
I have had mine round out. I took a thin square piece of aluminum made an oblong hole to match the lock and put it on the inside of the door and held it in place with pop rivets.
Turtle_n_Peeps
I had the same thing going on with my old trailer. I sold the trailer before dealing with it.
If I did deal with, I would have sandwiched a piece of aluminum between the foam and fiberglass. I would use a good bonding epoxy like JB weld or something similar. Clamp it good while drying.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
