Dexter easy lube axles
Bob_Vaughn
CAUTION BEWARE...... do not let anyone use a grease gun to pump grease into these axle's it will blow by the seals and put grease on your brake shoes and magnets and make them useless......I let a service guy talk me into letting him do it to avoid having to remove the wheels and bearings and grease them. I found out the hard way. Today I had disc brakes installed and the inside the hubs was saturated with grease and the shoes had soaked it up and were useless to stop the trailer. So be forwarded.......
22 REPLIES 22
mosseater
I'll get the popcorn....
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
Slownsy
The grease can stil get true so don't do it or learn the hard way.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
kennethwooster
I had some on my previous trailer. I talked to a Dexter dealer. He did not like them. I greased mine a time or two but made sure grease in axle was warm by driving around. I put just 2_3 pumps in. It was recommended to me that they still needed hand greasing. My Cameo came without and I'm glad.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
Dave_H_M
Did the service guy have enough seniority to merit a shirt with logo on it? :B
fj12ryder
Well, let's hope the same service guy didn't talk you into the disc brakes. 🙂
Howard and Peggy
"Don't Panic"
4aSong
BB_TX wrote:
If done right by Dexter directions they work fine. I have done mine three times with no problem. You just have to do it slow and easy and follow directions.
If done correctly following Dexter Directions they work fine as BB_TX states. If you are not knowledgeable on the proper procedure you end up blowing the rear seal by not correctly following the Dexter directions. A video showing the proper procedure is available at the following link.
Lubricating Dexter Axles
M & N
Tundra TRD V8 4x4 w/Leer Shell
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
BB_TX
Campfire_Time
Thanks Bob. Just goes to show that even those who should know how these work, don't.
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
