Receiver = the part bolted to the TV's rear end. Most likely the frame and if a
CUV, the sheetmetal body panel 'back there'
Draw bar = the metal piece that goes 'into' the receiver and is held by a 'pin'
that goes through the holes of the receiver and the draw bar inside the receiver
'pin tube'. The draw bar is 'half' of the WD hitch. If no WD Hitch, then the
draw bar has the ball bolted directly to it. Basically the part that has the ball
bolted to it...on some WD Hitch's, the ball is farther back towards the trailer.
Like the HA and the like
Hitch = the setup that marries the trailer to the TV. Consists of the above draw
bar that has the ball and the other 'half' is the bars (round, trunnion, etc).
Just the draw bar with the ball bolted to it, will weigh in the 20-50 lb range
Dependent on it's rating
WD Hitch setups can weigh from 100-to several hundred pounds
As to where the weight goes...it gets complicated and mainly to do what type
(architecture) of hitch system
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
