dually tires
machunt
How is everyone inflating there tires on there dually.
17 REPLIES 17
sowego
On ours the valve stem for the dual is accessible through the hole in the wheel of the outer wheel. The big "however" is ...I do it because my hands are smaller. If "he" had to try to do so it would be almost impossible. If you have the type of valve stem caps that don't have to be removed that can also be a plus. The next option is to mount valve stem extenders to the outer wheel.
2002 Tiffin Phaeton
2005 Malibu Maxx toad
PenMan
I had metal valve stems installed so both the outside tire and inside tire valve stems are pointed out. Same as filling one tire but do it twice. So much easier than trying to fill the inside tire with one of the dual chucks. Tire-Man Valve Stems
Chris and Jane
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
cpmath
Air compressor with air chuck attached.
