Good Diesel Service in Greater Seattle Area
pompomgirl
From DH:
Replaced the OEM radiator in my 2007 6.0 Powerstroke diesel because of unrepairable leaks around the fittings on the bottom header tank where the transmission cooler lines enter. The replacement is an aftermarket radiator that is all aluminum, no plastic header tanks. This supposed to be a permanent fix for the leaking O-ring seals in the stock plastic tank. The radiators are common for the pickup trucks, but was a special order for the E-series chassis. Note: the pickup rad will NOT fit.
Steve has a somewhat grubby shop, in an out-of-the-way location on the outskirts of Monroe, WA. What you get is professional, knowledgeable repair work at a very reasonable price. I set up the appointment a week ahead. Steve had the new radiator waiting and in two and a half hours the job was done, leak checked, transmission topped up and ready to go for our summer trips. The cost was $300 less than the nearest quote I had, and about half the Ford dealer price which was for another stock radiator.
Steve is a Powerstroke specialist and offers all manner of upgrades for these engines. He also does other light diesels, like Cummins. I have no financial interest in this little report, just thought Iโ€™d pass it along.
Steve at Sno-Valley Diesel. 360-805-4046
8 REPLIES 8
pompomgirl
www.snovalleydiesel.com
Sno-Valley Diesel
20101 N High Rock Rd
Monroe WA, 98272
360-805-4046
steven@snovalleydiesel.com
M-F 9:00am - 5:00pm
Sat & Sun Closed
Lyrikz
pompomgirl wrote:
From DH:
I live in monroe.
Good to know.. Can you post up his address/ph#?
pompomgirl
Ah, didn't know about that one. I will.
mockturtle
Hope you will also post a review here: http://www.rvservicereviews.com/
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
pompomgirl
If you go there, get explicit directions. Google doesn't tell you that he's all the way at the top of the hill up a windy road, and his road isn't well marked. DH says it is fairly easy to find, but you have to have confidence to keep going.
pompomgirl
Oh, he can. I guess DH forgot to say it was our 31' Coachmen Freelander that he worked on.
wirenutz
I will give him a call when I get back home to see if he can get a medium duty sized truck into his shop
2007 All American Sport Toy Hauler 38 foot, 14,400 LBS dry weight
1999 Four Door Freightliner,new 6 Speed Auto, new Cat Motor, 12,600 LBS, rear air dump, lowers rear by 3", air activated rear locker, air ride seats, air ride cab, air ride suspension
Fishinghat
Thanks for the tip.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
