Help identify WD rating
ajriding
I bought WD parts used. It is the style that hangs from chains. I do not know brand, but the spring bar is stamped with 22210-G and on the other side 750.
They are pretty stout.
I am not sure if it is rated for 10,000 or 8,000. I am doubting it is for less.
The trailer is much less in weight, but it works.
If you have some with numbers maybe yours are similar and that will be a good start.
3 REPLIES 3
ajriding
Thanks Fisherman.
Yes, it does matter. A softer spring is typically used on a lighter trailer. A softer spring will bend much farther than a stiff spring. A heavy trailer will have a heavier frame than a light trailer. A heavier frame (stout) will handle the higher spring rate of a stiffer spring before bending. Heavy spring on a light trailer frame is higher chance of bending or damaging the frame. Yes, it does matter.
Fisherman
How about this: Reese weight bars
Lwiddis
If it works and your public scale weights are within limits/shifting back to the front TV axle etc., does it matter?
