House Batteries
beetleman
I am trying to figure out why my house batteries are not charging when it is plugged into shore power. The batteries will charge when the engine is running. The microwave and other 120V items will run when plugged in. I have checked all the GFi outlets. Checked battery connections. I have not found anything blown fuses with the converter. The only local rv tech is booked for several weeks. Anyone have and idea what I can check?
7 REPLIES 7
Veebyes
Converters are not expensive. Simple to install also. Surely if the converter is at fault this is a very easy DIY job. Trouble shooting looking for loose connections or blown fuses is not hard either.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
wa8yxm
House batteries not charging on shore power.. See line diagram
Shore---Breaker box---Converter--Fuse----Batteries, fuse box, other 12 volt stuff
Suspects:
Trippped breaker
Loose wire breaker box (I often say many RVers have a few screws loose.. THESE are the screws I am speaking of).
Bad converter
Blown reverse polarity fuse.. THIS fuse may be one (or both) of the two right hand fuses on your fuse panel, or it may be in the converter. and there can be up to 3 of them in aparallel. Usually 30 amp ATC fuses.
Bobbo
Do you have a battery disconnect switch? If the battery is disconnected, it won't charge.
Bobbo and Lin
beetleman
I will do both suggestions in the morning. Currently we are have a thunder and lightning storm.
rrupert
Deleted.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
sch911
Make sure the converter is getting it's 120V AC input. Generally it's on one of the AC breakers.
Test the battery voltage at the posts with a voltmeter with and without the converter running and report back the results.
OEM Auto Engineer- Embedded Software Team
darsben1
Could I trouble you for some info on your rig.
But it sounds like the battery charge function of your converter is shot. Can you get to the converter and check the charging circuit output when plugged in. Please post model of your converter
Traveling with my best friend, my wife in a 1990 Southwind
