Installing Smi Air Force One into a Country Coach Chassis
doc_brown
I'm going to install the SMI AF1 into my 2004 Country Coach Inspire and I would like to hear from anyone who has done this to a CC. It appears some air systems can be tapped into easily while others require a little more work.
Steve,Kathy and Josh
Morpheus(Basenji)at Rainbow Bridge
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2014 Jeep Wrangler Unlimited Sport S, Air Force One Braking, Blue Ox
2 REPLIES 2
JR45
I have an 06 Country Coach Inspire and had the Air Force One installed with no problems, plus it works great.
I'm on the Yahoo forum also plus you might look at iRV2 forum in the CC section.
I had mine installed. If you have any questions give SMI a call they are great.
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
sdianel_-acct_c
are you on the Country Coach Yahoo Group? You might find more info there.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
