Is a 2010 Toyota Corolla modifiable as a tote?
travelteacher
I have a 2010 Toyota Corolla and am interested in finding out if I can modify it so that I can tow it directly behind the motorhome without a trailer or dolly?
Does anyone have experience with this?
6 REPLIES 6
Gjac
Is it a manual transmission or an automatic transmission? The manual is flat tow able the auto is not.
Bumpyroad
assuming that it is just a front wheel drive, just use a dolly.
bumpy
Jebby14
trailer would be cheaper and easier plus you wouldn't be putting the wear on your car
Q: Whats brown and sticky???
A: A Stick....
Y-Guy
Moderator
Moderator
I did a quick look. Manual says, "Your vehicle is not designed to be dinghy towed (with 4 wheels on the ground) behind a motor home."
Remco shows different possibilities depending on Auto/Stick and which engine.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
Heisenberg
This is the place. Remco might make a pump.
2013 Winnebago Sightseer
2017 Colorado
agesilaus
Better to ask in the Class A forum, this one is for trucks that tow trailers.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
