Is my brake controller shot?
BZ_MAN
Just took the camper out for a short trip to dump my tanks and noticed that it was pulling harder than normal. I look down at the brake controller (prodigy p2) and the numbers on the readout are going all over the place without even touching the brakes. I get home and put it in park and it is still doing it. I went back to the wheels on the camper and sure enough you can hear the brakes working. So do you think my controller is shot or could it be a bad connection somewhere. Thanks
2008 Chevrolet Silverado 1500 Crew Cab Vortec Max
2015 Keystone Passport 3320BH
2006 Rockwood Roo 23SS - Sold
1 REPLY 1
memgrove
Check the plug on the back of the truck for corrosion. You may even have to open the plug up and check inside where the wires connect to the blades. When I would run the salt spreader in the winter it would cause this in the spring. Sometimes the corrosion was so bad I had to replace the whole plug.
Mike
2006 Chevy 2500 4X4 crew cab Gasser
2013 Dutchmen Denali 311 BHS (Love the trailer HATE the manufacture!)
