Jeep Grand Cherokee
michbill
This is Mich Bill,
We currently have a 2001 Grand Cherokee Lorado 4X4 toad. We love it. However, we are looking for a newer one. The FMCA towing guide says that it has to have quad drive or trac. I'm not sure what that is. I have been told that this is only on the Limited and only comes in 8cyl. We are looking at 2008,9 or 10. Does anyone have experience with these?
Thanks
Bill
5 REPLIES 5
haddy1
If you have a transfer case that allows selection of high and low, you should have a neutral position. It's the single speed transfer cases that can't be towed 4 down.
2019 Tiffin Phaeton 37BH
2018 Grand Cherokee Toad
summerhouse
I am certain our 2015 Grand Cherokee Summit has a neutral switch for disengaging the transmission. However we do not tow it. We tow our 2014 Jeep Cherokee Trailhawk (DH daily driver) I do recognize the switch though, since I am usually the one who puts the Trailhawk into 'tow mode' when we hook and unhook.
โ€œLight hearted I take to the open roadโ€ฆ Healthy, free, the world before meโ€ฆ The long brown path before me leading me wherever I choose.โ€ - Walt Whitman
KD4UPL
Basically the transfer case must have a neutral position. Some do, some don't.
transamz9
When I had my Jeeps you had Quadra Drive and Trac which is AWD. You could only select four wheel high, neutral and four wheel low. Then you had Selectra Trac which was like a normal 4wd. You had 2 wheel high, 4 wheel high, neutral and 4 wheel high.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
sch911
Quadra Track II and Quadra Drive II have the T-Shifter and Neutral button shown in this image.
Quadra Track I does not.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
