Sep-24-2014 10:56 AM
Sep-26-2014 10:30 AM
BradW wrote:Off Pavement wrote:
I like that Currie set up, but I think I might like using an aftermarket bumper with these adapters better.
http://blueox.com/p-1570-bx88291-bx88296-off-road-adapters.aspx
Thanks all for the very helpful suggestions,
Brad
Sep-24-2014 09:14 PM
Sep-24-2014 08:04 PM
Off Pavement wrote:
Sep-24-2014 05:02 PM
Sep-24-2014 01:51 PM
Sep-24-2014 01:10 PM
Sep-24-2014 12:16 PM
jrp wrote:
The original tow brackets (Roadmaster style) attached at the front upper end of the frame and had no impact on ground clearance. Once I replaced the stock bumper, the issue was that the new bumper used the same mounting holes in the frame as the Roadmaster tow brackets. The tow brackets couldn't be bolted on after the new bumper had used those mounting holes, or vice versa. Since the new bumper steel plate was just as strong as the frame steel, my solution was to go with different type tow brackets that mount right on the front of the after market bumper (with new drilled holes), but still matched my Roadmaster towbar attachments.
Sep-24-2014 12:10 PM
Sep-24-2014 12:03 PM
Sep-24-2014 11:35 AM
Sep-24-2014 11:31 AM
